Hi, I have what I believe to be a 3.5hp Briggs & Stratton style engine, not sure on model as it was a supermarket branded mower. I have drained and filled with fresh fuel and oil, replaced spark plug and cleaned out carb with carb cleaner. I am getting no spark from the spark plug with a reading of 2.1k ohms when testing between the plug end and the body of the coil. I have also used the business card method to ensure correct spacing between the coil and flywheel. Is the coil in need of replacement?
Any advice or suggestions would be appreciated.
