Repairs Mower won`t go forward
forrest
greetings,
I have a 2006 yard machine that won`t go forward it goes backwards just fine and goes into neutral fine but when I put the shifter in forward it won`t move it just makes a loud metallic ratcheting sound that is coming from under the seat.
The drive pulley on the transmission is turning. I removed the transaxle and noticed that the drive pulley is very warped. I turned the pulley by hand and the axles didn`t move, so I removed the pulley and reseated it onto the star shaped hub under it, I tightened the pulley nut and turned the pulley by hand and the axels turned in both forward and reverse.
I thought that I had fixed the problem so I put everything back together, started the mower, put it in forward and,..Nothing, just the same metallic ratcheting sound.
I ordered a new pulley (since this one is very warped) and a new pulley hub with the star pattern to fit the star shaped hole in the pulley.
I don`t think a new pulley is going to fix the problem since the old warped pulley works fine in reverse, so what should I check now?
mechanic mark
http://www.mtdproducts.com/equipmen...Code=05&modelNumber=13a1762f700&serialNumber= information your tractor
check out pages 10 & 11 first manual, items 62 & 63 idler & variable speed pulley's for replacement by removing both & check out bearings for being shot, I would also replace belts at this time.
http://www.wfmfiles.com/download/Te...m_-_Transmissions_&_Differentials(691218).pdf
http://www.mtdparts.com/equipment/mtdparts/753-05851 see troubleshooting section
http://www.ebay.com/sch/i.html?_nkw...e=c&geo_id=10232&keyword=mtd+618-04034&crdt=0
forrest
KIT-SERVICE REPLACEMENT 618-04 - 753-05851 see troubleshooting section
mtd 618-04034 | eBay
I checked the variable pulley and the idle pulley they both seem to be ok.
I removed the top from the transaxle and nothing was broken,bent or worn, no chips on any of the gears,the fork, the clutch collar and everything were in perfect condition.
I put it all back on the tractor and still the same problem.I put the back end on jackstands so the wheels were off the ground, when I put it in forward the wheels turned.
When I get the new drive pulley I`ll put that on and replace all the belts and see if that fixes the problem,if that doesn`t fix it I guess I`ll just buy a whole new rear end assembly.
mechanic mark
Try pulling rod at backside of tractor, used for transporting without cranking, & try pushing tractor forward, still making noise?
