I have a craftsman 16 HP. 917.27535
I replaced regulator. Then drove mower. It ran good then started running rough.
I did have trouble with installing the fly wheel How do you know if the flywheel is tight enough?
I thing I could have damaged the key in the flywheel
Thanks in advance for your help. If you need more info. Let me know
