Ok, so Im baffled. I have to run the mower half choked or it surges wide open throttle then idle, and repeats over and over. Reading up everyone says that the surging is a lean issue caused by a dirty carb. So I took the whole thing apart and cleaned it all out, used a pin to ensure the jet is 100% free of obstructions. It still surges. I changed the spark plug and air filter, still surges. Checked the flywheel key to make sure that it didnt break off and advance the timing. Its good. reassembled and still surging.
So now I thought what if I just bypass the governor and just hold it still so it cant surge? runs fine, I can run with no choke and adjust the speed manually, runs 100%. So I tried making the governor spring tighter, its pretty much impossible to get right, its either too tight and runs WAY WAY too fast, or too loose and pulses.
Its a hydro gov, not one of the fan style ones.
Is there any way to adjust these and resolve this issue?
