Mower starts but bogs out in 5 - 10 sec.
rdshrk
Have a snapper with a robin 4hp 2 stroke. It starts but will not continue running. Have replaced the plug, cleaned the carb several times but still will not run more that 4 5 sec.
Sometimes cleaning a carb isn't enough. You often have to rebuild the carb or replace it. Also check to see if there may be a clog in the fuel lines.
