Mower Stallout
pjpolk
Mower, has been in the shop a couple of times for starting problems changed carburetor, started and fuel line.
The last time the repair shop called, problem prognoses was a valve adjustment.
Lawn mower ran great for 1 month and stalled out the same way it has done in the past this afternoon.
Thus meaning the Mower refuses to start, could this be the valve problem and how do I correct it.
Any light that could be shed on this problem will be very much appreciated.
Thank you
P J
Polk
Boobala
We need some info. about your mower .. ( use my info below as example)
