Mower quit wile cutting wont restart
hodakaguy
I was cutting my grass on my Murray LT75. It quit and would not restart. Turn the key and nothing happens. I can jump the solenoid and engine spins fine, but no spark. When I disconnect all the wiring to the engine and jump the solenoid, good spark. With the key on there is no power to the lights. I am prsuming I have a bad safety switch,. BUT how can I tell which one is bad
Did you shut off your PTO?
When you jumped the solenoid and engine spins...was the key in "run" position?
Key was on when I jumped the solenoid, I dont have a PTO.Did not think of a fuse. That may account for head lights not turning on?
You have a handle you swing to engage blades?
It must be off to start...was my point
It is easy to forget to cut off PTO or swing blade engagement handle when your mower just dies while mowing...
