Mower dies when blade engaged and moving
choreboy
I can go forward and reverse. I can have the blades engaged with the clutch in, but when i try to move forward with the blades engaged it chokes and dies. thoughts/solutions?
Post the model number and brand of the mower.
Likely it is a switch on the seat or shifter that is the problem area.
Bolens by MTD, 6 speed shift on the go Lawn Tractor. runs forward and backward without blades engaged, can engage blade in neutral but when going forward it bogs down and dies.
