Hello!
The issue is with my Lawn Boy LT12H lawn tractor.
For some reason, one of the deck wheels will occasionally come off of the deck. The wheel on each side is held onto its shaft with an external snap ring which seats into a groove in the shaft. I'll be merrily driving along, and suddenly realize that I'm scalping the grass, and will turn to see the wheel lying behind me. This has happened a few times last year, and once this year.
Also, there are some extremely thin washers on the shaft, between the wheel and the deck itself. I was always able to locate them when the wheel came off in the past, but wasn't so lucky and lost them this time. Are they an easily found, fairly standard item?
Any ideas or input appreciated. Meanwhile, I'd better stock up on some more snap rings! :thumbdown:
