I have a JD 425 lawn tractor. where is the c;uttoff switch for the reverse pedal. I want to disable it. Its driving me nuts. I cant nose into an area and mow backing out.
The quick answer is what every you are doing when the mower dies you will follow that under the mower till you find a switch it touches. So if peddle is pushed for reverse follow it back. If gear shift lever is used then follow it.
