paroughneck
- Apr 2, 2012
- 1
- 1
I have an ariens minizoom with a briggs intek 14.5 hp motor. Around the end of last summer it started to have this issue, we had a lot of rain, so I figured since it had been outside it got water in the gas. I got to it today, I drained the gas from the tank, the lines, and the carb. I put new gas in, with an oz or so of lucas deep clean. It fired up but still has the same problem. It backfires, with quite a bit of smoke coming out during the backfire. It sputters, it wont come to a full idle. Not like its trying to die, just like something is clogged somewhere. I let it run for a good 30 mins, thinking it would burn off the bad gas. But it still runs the same. I was thinking maybe the muffler has some carbon build up, and I will get to taking that off tomorrow to see. When I took the solenoid and cup off the carb, everything seemed ok. The solenoid clicks when I turn the key, and I can feel the plunger going in and out. I am not 100% that it is, without taking it off and turning the key, but we will assume it is. Any ideas? Something I can try or check for? My dad mows a rather large cemetery, and has a guy who fixes all his stuff, but I would like to take care of this on my own if I can. The grass isnt getting any shorter, and he isnt the quickest, or the cheapest for that matter. Any help would be greatly appreciated. Thanks!
