Hi all,
Just got my John Deere D-130 out of the shed after winter. Found a mouse nest in the motor which I cleaned out.
However, my motor won't crank. The battery is fine and the starter spins... but the engine doesn't even try to crank. Most posts I've read seem to point at the Solenoid, but me, not being very mechanically inclined, can't understand that if the solenoid doesn't work, then why is my starting spinning and spinning?
Thanks All !!!!
Thanks All !!!!
