motor upgrade
BeachBoy1942
my 21hp intek motor died and I have chance for a 24 hp intek Briggs twin; will this motor fit my Husqvarna built Craftsman?
Yes, if the crankshaft diameter and length are the same on both engines. Also depending if going from single to twin, could require some exhaust changes and possible wiring changes. You may have to move the charging system from the old engine to the new engine if the new engine doesn't have enough output to run the required items and charge the battery.
