Model 10523, (1996), 2-cycle, self-propelled.
dmcain
Help ---
Skips / hiccups erratically until warmed up.
Also, after warmup the rpm's increase and seem to override the air-vane governor.
Any suggestions appreciated!
Try giving the carb a good cleaning and check to see if the spring on the air vane is worn or broken. Hope I was of some help. Let us know if you get it fixed in case someone else has the same issue.
nothing like the smell of 2-stroke smoke and fresh cut grass roasting on the muffler!
