Missing Model Tag, Please Help Identify
howaya
I recently acquired this 20 HP 46" Yard Machines tractor and am in need of a model # to make the right parts purchases down the road. In addition to the pictures below, The Briggs and Stratton engine numbers are as follows:
Model 461707
Type 0143 E1
Code 9912085A
An MTD agent told me those numbers suggest it is a 1999 model year with an 18.5 HP engine, which suits at least a dozen different tractor models. Hopefully the pictures will narrow it down to a single model. I wonder if the "Industrial/Commercial" label in picture 1 is an indicator of a 14 series model.
Thank you Mark. The diagram in link #2 does look similar. But the model # is missing from under the seat, so I cannot be sure if 13AN601H729 is a match. I'll see what I can find out and, in the meantime, welcome all additional input from you and others.
