louisjerry
- Mar 12, 2012
- 2
- 4
Hi I have a 24 hp briggs & stratton model 44M777,type 1193B1, couple weeks ago engine wouln't run inless I sprayed starter fluid would stop when I stoped spraying,found problem with help ,pin was half out on carb float,fixed that cleaned carb bowl and checked gas shut off soliond,, will run good now,but have to spray starter fluid be it starts then runs good,after it warms up will start good,next day have to spray fluid again,took gas hose off by carb,turned it over have gas comming out of hose,how much should come out,or is there a setting I can make so it will start without starter fluid,put new air filter on,also fuel filter,woud appricate any help I can get thanks for your time ,Louie
