mdavid390@aol.com
Duane Davidson
I have a 60 inch z turn bobcat. Bought around 1997. Have used it commercially plus the 10 acres at home. Have only replaced the mowing deck and engine once. It now has a 25 hp kaw engine that works fine but is not charging the battery and is burning up switches for the clutch that runs the blades. Wife can't mow. Help!
mechanic mark
Check all wiring by hand especially grounds & wiring from pto switch to pto clutch, look for bare wires, burn marks, also check fuse box for melted plastic & burn marks, check seat switch & wiring for same.
