lawnbugger
- Jun 27, 2024
- 1
- 9
I bought a used Craftsman Yard Beetle,guy said it needs solenoid and shift cable but runs by direct jumping the starter.
Got it home and does not fire up,direct jump to starter and turns over.I got a new solenoid and nothing on the key??? I direct jump the starter and it turns over but not getting spark.
I pulled the carb and cleaning it but don't know why I'm not getting spark or turning over by the key.
It also will not go into neutral and I have pulled the 2 shift cables that are bad,won't shift to neutral by hand?The shifter moves by hand back and forth?
So no crank on key,no spark and no neutral????
