Masport/ Morrison Mini Rider.
geobee
Hi all, looking for a workshop manual for the above. Mainly just a good layout of the belts and pulleys would be a good start. Purchased the unit not running, and there is one pulley missing, being the 718-04407 hub pulley. Also there is the missing spline shaft that the pulley spins on. I cant see a part number for that shaft in the parts manual, which I have managed to find.I assume this pulley presses up against the rear of one of the drive belts, as I feel its just a flat roller, not a v pulley? Any clues would be great. Cheers. Geoff
Hi all, disregard the above. Worked it out. The only thing that has me stumped is bracket part 36 part no:783-07248 has a pulley on one end, but nothing on the other, just a hole, the parts diagram doesn't show a spring or anything else fitted to the bracket. I thought it showed that hub pulley fitted to that bracket, that is what confused me. Cheers
