Masport 660 front roller.
Martyn1973
Hello, I've just joined this site today, and have a question someone may be able to help with. I bought my Masport 660 a couple of months ago, after re-seeding my 500sq foot lawn. I'm not sure if there is a problem with the front roller as when the lawn mower is lowered beyond a certain point, there are visible marks left on the stipe. Any ideas?
mistermowerman
Hello,when you say visible marks are they like lines going across the stripe as it could be your cylinder needs adjusting to your bottom blade.
Martyn1973
Hi, no, the lines are going down the stripe. I have adjusted the front roller as one side was slightly lower. There is an improvement, so I think I'm on the right track to solving the problem. Thanks
