Manual for MTD Yard-Man HE4160
Tiggy
Hey all,
I hope you guys can help me get a manual for my mtd Yard-Man HE 4160Only numbers bellow the seat are:
13AE414E643 / AC100L10304
I am from Belgium and can't seem to find a decent manual.
I need it to know what the switch under the seat (on the left) is for (a manual switch) and were the buzzer is located for the sensor to see if the grasscatcher is full. I hear no buzzing when it is full and wann check what is broken.
I hope you guys can help me out :)
The switch you refer to is a safety switch. When it's switched on the engine will cut out if you leave the seat. With it switched off you can walk away from your machine (or fall off it!!) and the engine will continue running.
Hope that's clear for you.
