Making a Cab
jt2953
If i make a cab for my mower what should i use for a frame? How should i mount the frame to the tractor, and where? What should my sides be, sheet metal, cloth?
JohnG
I purchased a vinyl cab for my snowblower that may work for you. It is built out of aluminum tubing with all 3 sides heavy duty vinyl. I believe it could be adapted to your tractor.
