When I got this engine, it was running poor on #1 cyl. #2 cyl doing all the work, but #1 will run by itself but poor. Spark plug gets black dry soot.
1. Install new plugs and Check compression on both cyl, they are the same.
2. Leak down test on both cyl, less then 5% leak.
3. Removed intake and carb, check gaskets and for water, dirt in carb., none. Intake gaskets good. No cracks in intake
4. Check key on flywheel and install new module, no change.
5. Removed #1 cyl, check all valves and guides. Lap both valves and check clearances. Intake set at .005 and Exh at .013, in spec for year of engine. Check cam/valve lift.
6. Install all cyl parts and new gaskets, and it's the same
I'm lost. This engine has done this when I install it NEW back in 2000.
Help from some one. I am a 35 year small engine mechanic and I lost!
I must need that 36 year. LOL
