I was cutting the yard and the blades just disengaged. I pulled and pushed the pto knob to no avail. The only trouble shooting I could do since it started raining was to have the mower running and engage the PTO switch and lift off the seat. The motor stopped running as it should have. With the motor off and the ignition switch on if I engage the PTO I do not hear the clunk sound of the PTO engaging. Before when I had solenoid problems with the key on and motor not running if I engage the PTO i would hear the clunk. That is how I know I should be hearing that sound.
I have googled to try and find the wiring diagram but could not find it. My next step is to check the PTO switch for continuity. I hope the switch is the problem and not the PTO itself.
Any help would be greatly appreciated. You all helped me solve the solenoid before i went to training so I feel confident you can help me again.
