LX277 creeping in forward and reverse
arch252
Is this a neutral adjustment issue? I can't find any links to this issue or how to adjust on an LX model. No videos, no info. Can anyone help?
shiftsuper175607
1)Check for proper trans. fluid level.
____________________________
2) Check for proper adjustment of forward/reverse petal
To do this...
depress reverse pedal twice...let it return to neutral position
measure distant between floor mat and tool mark near bend of pedal (hopefully you can find this mark...maybe the ruler can help you)
It should be 1.97 inch plus or minus .08 inch
Let me know what you find...
shiftsuper175607
To do this...
proper tool mark location is where sheared steel edge intersects with the round portion of pedal bracket.
If not within specification, adjust foot pedal rod length
___________________________________________
Adjustment of foot pedal rod length
1) In front of right rear wheel, locate Jam nut on forward/reverse control rod. Loosen jam nut
2) Remove the spring clip pin and disconnect forward/reverse control rod from intermediate shaft plate.
3) Turn ball joint rod and on end of control rod
---lengthen the rod to raise the reverse pedal.
---Shorten the rod to lower the reverse pedal.
4) reconnect control rod to control lever and retain with the spring clip pin
5) press reverse pedal twice and allowed to return to neutral. Check measurement. Repeat adjustment procedure until within specification
Have one to sell? Sell now
- Have one to sell?
Details about
SIEMENS VF4-45F11 12 VDC 40/30A RELAY
arch252
I guess what I was asking was can anyone send me a link to the transmission neutral adjustment on the LX series?
