weak spark hard to start what could it be
gjt Member Joined Mar 9, 2013 Threads 2 Messages 12 Mar 9, 2013 / Lx186 #1 weak spark hard to start what could it be
B Buckshot 1 Well-Known Member Joined Dec 30, 2012 Threads 1 Messages 234 Mar 9, 2013 / Lx186 #2 :smile: It could be anything. What type of LT and what engine?
gjt Member Joined Mar 9, 2013 Threads 2 Messages 12 Mar 9, 2013 / Lx186 #3 JD LX186 w/ 17HP Kawasaki Engine
R Rivets Lawn Royalty Joined Mar 11, 2012 Threads 59 Messages 15,305 Mar 9, 2013 / Lx186 #4 Only guess I can make is dirty carb, which means clean and rebuild carb. Post model numbers, please.
B Buckshot 1 Well-Known Member Joined Dec 30, 2012 Threads 1 Messages 234 Mar 10, 2013 / Lx186 #5 :smile: Ohm out the igniter and mag. Sorry do not have the numbers, but the procedure and numbers can found online. Also check all grounds.
