Engine had been running fine noticed this morning that gas was running out of the carb bowl. Got a new gasket for the bowl replaced it now the mower will half way run then shut off. Now motor will start but will not stay running. When it is running mostly with choke on and it starts to shut off you can plug in carb chamber solenoid and it will keep running a little bit but not if you leave it plugged in, you just have to touch it. If left plugged in it will shut off. If you do get the motor running with out the choke on it still will not run with the solenoid plugged in. Thanks for any help. It is getting fuel from the pump. Clean gas, air filter is also clean does it with air filter off.
