I have a John Deere LX-277. The blade nearest the output side of the mower no longer turns. When the PTO is engaged the blade binds up and causes the engine to die. The other 2 blades seem to be turning normally. When I attempt to turn the problem blade by hand it quickly binds up and will not turn. The other 2 do not have this problem. The pulley and spindle turn when the blade is not attached but once the blade is installed it refuses to turn. I thought possibly the bearings may be broken but with the belt off I am able to smoothly turn the pulley. Any thoughts on what may be causing this?
