Lucas Heavy Duty Oil Stabilizer
Go-Rebels!
I'm running a 50/50 mix of Lucas Oil Stabilizer + 10W-40 oil in my 1975 14hp single cylinder Kohler running in my Model 1450 Cub Cadet lawn tractor. I've been running the tractor once a week to cut a 1/2 acre lot and the oil burning has gotten excessive where I need to had half a quart 10W-40 every 3 hrs run time. I'm not willing to rebuild the motor and was wondering how high I can mix the % of Lucas to oil. Today with a 50/50 mix I can get 4-5 hours before adding another 1/2 quart of the oil mix.
Lawnman23
Piston rings are most likely shot. Does it smoke at all? If your not wanting to repair/rebuild, running heavier oil is about your only option to minimize oil loss.
Go-Rebels
Yes, rings are likely worn out after 48 years continuous use. Yes, the engine moderately smokes. Because this is a splash oil system, will 100% Lucas fail to lubricate the top of the motor?
Lawnman23
Sounds like you run this in summer only for mowing? No winter/cold use?
Per Lucas, https://www.lucasoil.com/pdf/TDS_HD-Oil-Stabilizer.pdf 80% at most is recommended for mixing purposes. Could it be run 100%, sure, others may have an opinion on that, I don't have any personal experience to say otherwise.
Me personally, I would just switch to a 5w50 or 20w50 and accept that it will still smoke some and consume. Being a L-head, valve stems only get "lubed" via oil mist from a hot engine, not directly from splash/pump/lifters. Anything in the crankcase will get bathed in fluid regardless of what it is.
Go-Rebels!
Thanks! Yea, 20W-50 is another good choice to minimize consumption.
PTmowerMech
Is oil unstable? What's the actual purpose for a stabilizer?
MParr
Try a 20W50 without any additives.
You will need a rebuild, new engine, or a new machine in the future.
