LTX1040 mower, tried to install mulch kit....
bugme
and it was easy but each time I run the mower through grass, the plug falls off. Now I know why they used the rubber strap to hold the plug tot he mower so it does not get loss. Called Cyb cadet and that is the correct part and are aware of the problem but NO FIX!
bugme
Continuance ..... Has anyone removed Discharge Chute Assembly and install just the Mulching Plug? Has anyone mowed that way w/o the DCA?
