LTX 1050 KW WONT TURN OVER
btetrick59
Looking for Help, battery is charged but when you turn the key the solenoid clicks but the starter is not turning,
Have checked voltages at solenoid and it has 12+volts and seam to work as voltage passes thru ,but no voltage at starter.
Replaced the solenoid and it started, but half way thru mowing it ran out of gas and now it is doing the same thing again,
any help would be appreciated as the forest continues to grow.
