LT42 XT1 Not moving
bsacpo
Good evening,
I read cl10Greg post on the same topic here, https://www.lawnmowerforum.com/threads/lt42-xt1-not-moving.58640/#post-356142.As Riverts stated I checked the belt, idler pulleys, tight tensioner arm, and verified that there was no debris caught inhibiting the movements of any of the former. Everything engages and moves when i left the rear end, but not when the tractor has the rear wheels on the ground. Is this the transmission? Model # 13AOA1CS010. Thank you.
mechanic mark
