LT160H482BV hydro axle long shot questions
hardknox00001
I have basically a LT 16 with the hydro axle with a vertical shaft vanguard engine. The mower is LT160H482BV and the hydro axle is made by Hydro Gear. The axle assembly is a 53036 215-1010S and the attached pump is a BDU-10S-120. The problem I have is in the 53036 assembly, and using their parts break down, I need a new 44080 and a 44079. I can get a 44080 but the 44079 is not available anymore through the manufacturer nor have I been able to find it online anywhere.
Has anybody got these laying around in a bone pile somewhere or know where I could maybe obtain them?
Short of that, does anybody know if another transaxle/pump assembly will replace the hydro gear unit in this mower?
TIA,
Randy
P.S. I can attach pics or pdf's of the associated parts drawings and lists, and pics of the actual parts to be replaced if needed.
