Repairs lt1554 will not move forward or back
mtaylor1949
I was mowing when the mower stop moving forward, PTO still engaged
hlw3
i have the same problem checked belts and the rod in the back both are ok
Check to see if the drive belt has tension. Idler pulley may not be putting enough tension on the belt.
EngineMan
Check to see if the drive belt is on idler pulley.
