lt155
studders
Hey, how is everyone doing out there. Good I hope. Well I got a question about a John Deere LT155. I walked into my barn the other to get it out and cut some grass and there was a large amount of fluid under the rear end. I have called around and everyone is telling me that it is a sealed unit. That may be I am not judging these peoples answers. So if it is leaking there has to be someway to either fill it back up or I have also read about repair kits. I am not sure where the leak is coming from. I got under there and wiped everything down. It may be coming from the gasket. I was just curious if anyone else has had this problem and if so what was the outcome. Replace the rear end or if there is in fact a repair kit. Also if there is a way to fluid back into it what type of fluid goes in there. Thank you for any help that anyone may give. Have a great day.
Sounds like a seal leaking or something. Look on the tranny and see if you can find a model tag. from the parts pictures looks possibly like hydrogear, but could be another tuff-torq. I am sure there are repair kits for the trannys, just need to figure out what tranny you have.
Sealed means they don't want the happy home owner going in there. They can be repaired. As IL said get us the numbers off the tranny if you can, it will take some digging, they like to hide them.
