Hey all,
I'm swapping motors in my lt155. I thought I was getting the exact same so it would be an easy swap. Well, same motor, different wiring. My old motor didn't have fuel solenoid on the carb, and didn't have an oil safety switch. The motor I now have does. The old motor didn't have a manual choke, the new does. I'm struggling with the wiring. Of course the connectors are different due to the different switches. I can swap out the carb from my old motor to solve that issue, I think, but not sure what to do with the oil safety switch. Is there a way to bypass that? I also want to cut the old 4 pin connector off and splice it to the new motor, but I'm not terribly confident. Any suggestions or direction?
Thanks in advance.
Thanks in advance.
