Lt145h38dbv (84239) won't start
slimshady69
I shut my mower off went to restart it now it won't turn over at all. Battery is fine, I have power to the starter. I think it might be the ignition switch but not sure. (Update): changed the battery solenoid and positive wire,and that wasn't it, so I took my battery charger hooked it up to the starter so i could mow lawn, anyhow now the safety switch on the seat works. So I pushed the clutch or brake whatever u want to call it, and it usually lets me get off the mower with out shutting off but it shuts off, by the way my mower is hydro drive, I'm thinking it might be the pedal switch but not sure.
seagiant
Hi,
If you can't read a Schematic and know how to use a VOM Meter...
You would be best to just take it to a Shop.
The problem could be a LOT of things and you need to eliminate things to find the problem.
Just sayin!
Now StarTech, you KNOW you were supposed to fly to his house and fix it for free. So ashamed of you........ ;)
More like the guy needs a lawn crew. Might cut his feet off using that mower in his flip flops and shorts.
The way things been going they not going let me out of the mental hospital anytime soon.
