After some running/cutting, the PTO kicks out and then back in when driving sideways on an incline, falling right.
It does NOT have those symptoms when driving hill straight up/down, or driving in the other direction (hanging left).
I thought may a low oil pressure switch, but a) oil level is good and b) running slightly higher hot viscosity oil (same cold viscosity) did not change the behavior.
Any suggestions?
Is there an 'incline switch'?
I have the seat switch disabled several years ago, so it is NOT caused by shifting weight on the seat.
Any suggestions?
