knevins5898
- Aug 17, 2018
- 1
- 1
My Cub cadet was services over a year ago. The belt came off and had to be replaced. I had the blades sharpened as well. Since then, it seems that when I mow thick grass, I have to keep it at the highest mower deck setting possible. If I set it any other level, once going though thick grass, it seems to have tough time keeping up with the thick grass and does not mow the grass well at all. You can hear the blades not going at full speed when in the thick grass. Once I get back on driveway of not-thick grass, you hear the blades speed up again. What could be the cause of this
