LT1045 2007 Blade speed slows down in thick grass
LT1045wrh
  • / LT1045 2007 Blade speed slows down in thick grass
Hi Everyone,
I haven't had this problem in the past, but when I was mowing the other day, the grass cuts fine but when I reach a thick patch (not anything the mower can't handle), the blades seem to slow way down. This has never happened before. I can hear the blades. Odd, but I know my mower noises and know something isn't right. It cuts fine, but this is something new. If I slow the forward movement way down to a crawl, no problem, but I can't go so slow all the time. It would take forever. It seems like the clutch is slipping, does that make any sense?
Thanks for your input.
Prof H :cool:
Hi Everyone,
Prof H :cool:
Sounds like the deck belt is worn down, or a pulley is going bad.
Deerlane
Make sure idler arm on deck that has the spring is free. A lot of times they will rust tight at the place where it bolts to the deck because its not lube at all. Then the belt slips under a load.
LT1045wrh
Thank you, I think the belt is just worn out. I have an extra belt, so I'll change it out and see if that fixes the problem. I don't hear any odd noise from the bearings and I don't see any bad rusting at the pulley spring, so we'll see what happens.
Thanks for the help,
Prof H :cool:
