I've had this machine since new in 1999 and have only had to do basic maintenance.
I recently noticed oil under the machine which appears to be coming from the hydrostatic transmission.
Has anyone run into this issue and if yes would it likely be a gasket or something else?
The oil leak is not obvious and must have been happening for some time since most of the transmission is covered in dirt and oil.
I have a hoist so working under the machine is not a problem so I was going to clean it up and let it run. Do I need to jack up the back wheels so that the wheels are turning to locate the problem?
Thanks
Thanks
