Sonofthe60s
- May 21, 2013
- 1
- 1
1042 with a Kohler engine, 420 hrs. usage. Runs beautifully until about two hours in of use - the PTO is engaged and the blades are turning, then it begins to sound like it is running out of fuel (plenty of fuel still left). The only other way I can describe it is that it sounds like the engine is "missing." I turn off the PTO and let the engine idle and the problem goes away. I re-engage the PTO and start cutting and a few minutes later - the engine starts acting up again. The tech who regularly works on it is stumped - carburetor has been cleaned, plug replaced, even starter coil replaced...already spent far too much. What could he/I be missing?
