Low power
thebeachworks
I have a 2010 LTX1050. THe last time I mowed, I noticed that reverse seemed a bit slower than normal, then after about 3 hours of mowing it was very slow going up a hill. The engine is running fine with plenty of power but it does not seem to be getting to the wheels. I checked the drive belt and tensioner which seem to be fine. Any ideas on what the problem is here?
Thank you,
Russ
d29
Hello,
If your machine is a hydrostatic it will be this giving you the problem, check for a obvious leak on gearbox.
Basically its losing pressure to power the gearbox.
thebeachworks
No leaks, but the oil is burnt. How do I drain the oil and what type of oil does this take?
Deerlane
Sounds like something wrong inside trany.
Bucky623
Did the oil change take care of the problem?
My GT2550 slowly looses reverse every few years and I have to replace the nylon bushings that support the forward and reverse peddles.
