I have a Simplicity lawn tractor with 20HP Vanguard engine, about 10-11 years old. I've had it for two years and it has ran fine without any strange noises. I just did my first oil change since I've owned it, and this new noise has appeared at startup, lasts for a few seconds, and then goes away. It sounds like valve train noise, but louder than I would expect. Seems like a dry start, but I chose an oil filter with an anti-drain back valve. I used Motorcraft FL-910S which has anti drainback. I used a reputable 5W-30 oil. What things could I check? I threw away the old filter before I noticed this problem, so I can't swap that back on as a check.. wish I could. I noticed it was also an automotive style filter (not Briggs), but not Motorcraft, and I don't recall the brand.
