Psychlopath
- Jun 8, 2014
- 64
This is a Snapper 33114S:
The blade holder came loose during a mow and the hole is now enlarged; it looks like this may not be the first time this happened by the wear I see, so I think I'm due for a replacement holder.
When I removed it for inspection, I noticed the only spacers or shims were on the top side of the blade holder, opposite of where the blade fastens, where I found two that had obviously gotten pretty hot and had fretted against each other at some point. I think I may be missing one and the existing ones need to be replaced in either case.
I'm trying to make sure it goes together with the proper parts, but I can't find a diagram or part numbers for what spacers SHOULD be there or if there are any missing.
Partstree.com is my normal go-to for a parts catalog but I'm not seeing what I need there. Anyone here have a diagram showing what spacers I need, where they go and some part numbers?
Also, just to be sure, is the bottom of the spindle, where the blade holder bolts on, supposed to be smooth or did it have splines at one point? Mine is smooth, but it could be from the blade holder being loose in the past.
