I am looking at a Honda Harmony 2013 mower. The owner says this is a well maintained machine and has all the maintenance records.
The only issue he says is upon startup on throttle change it smokes. He indicates it clears up. But it comes and goes.
I have had one of these for the past 20 plus years and know its a good machine. Although my engine did blow on mine a couple weeks ago.
He said otherwise this machine is perfect. Should I be concerned about this smoking issue? Any suggestions as to what could cause this that may be an easy fix. I don't want to purchase and have two mowers with blown engines.
Look forward to hearing from someone with similar experience or solutions.
