hello
im in the uk and struggling with a loncin engine which i know is used in the us alot
its single cylinder 87cc ohv pull start fitted to a cylinder mower
stalls and wont restart when it gets warmed up 10-20 after starting
im experienced in small engine repair but ive failed to fix this after numerous attempt
i dont know if the engine is overheating or if a componant is failing when hot
tried the following
new plug
tested coil immediatly when cutout/wont start... works fine
checked valve clearances
cleaned carb (carb has no mix screw fixed jets)
new air filter
new oil
fuel tank lid breather checked and engine ran without lid
fuel filter clean
this machine is 18 months old just out of warrenty and little used...
im stuck.. help
tried the following
new plug
new air filter
new oil
fuel filter clean
im stuck.. help
