tinner666
- Apr 23, 2012
- 2
- 3
When our box grader snapped it's welds, I decided to order a few replacement pieces, even after I rewelded the original and beefed it up. Whenever I decide on an attachmnet I need, I'll use one of them as a basis to build from.
You can see how I reinforced the unit, I used plenty of steel to also add weight. The log drag will handle as much weight as the tractor can pull.
The tractor is a Sears GT 5000 with a sleeve hitch. I also added plates on each side to the frame to stiffen the sleeve hitch frame an tranfer the load down each side of the frame.
