Just put a crank in a kohler SV730-0011 and I was wondering if I should use loctite on the rod bolts? There is oil up in the threads so idk how clean I can get it or if it'll even stick. I sprayed carb cleaner up in the threads. Can anyone tell me the rod bolt torque for this model also?
