Export thread
lock up?
#1
B
brownie52
cutting grass last night,went from 1st to revues and mower dies,I thank its lock in 2 gears?have body off and peerless pulley wont turn,wear to start?thanks, John Deere 170
#2
Nwatson99
Nwatson99
Okay you must be posting from a phone or your browser correction butchered your post.
Let me see if I understand you correctly
Last night you were mowing, while mowing you went from forward to reverse and your mower dies?
So you think your tranny is stuck between drive and reverse thus not allowing you to start your mower?
Now if you have a newer D170 and if I am not mistaking, when you go into reverse with your mower it will kill the engine unless you shut off the mower deck, so have you shut off your mower deck, push your e-brake, and tried to start it?
#3
B
brownie52
Its a older model 170.has none of the new safety,have the body,gas tank off,drive pulley on the peerless 5 speed will not turn.
#4
Nwatson99
Nwatson99
Got ya, well I personally only know of two things that has caused this:
1. Tranny went out a total
2. The linkage got stuck between the gears and it took about 1 hour to get to it and only 10 seconds to take a screw driver and flip it out so he could shift again.
Sorry that is all I have ever seen with the older model.
#5
B
brownie52
Thank you,well tear it down tomorrow,
#6
Nwatson99
Nwatson99
Please let us know what you do find, I hope it is the linkage and the screwdriver takes care of it.
#7
B
brownie52
needle bearings on the input froze up. hope I can git it back together if I find some, Thank you
